Old Mar 9, 2015 | 05:31 PM
onehundred80
Default Re: SRT-6 Antifreeze Change Procedure
I did my SRT6 the other year by draining the system, refilling with distilled water and running it up to temperature for a while, I then repeated this process again. Low pressure air was used to remove as much fluid as possible from the IC and radiator systems, and I drained the lower hoses once. When the car was running on distilled water the system was topped up as much as possible when hot up to the fill mark in the tank, I think that is not too clear in the write up.
I then calculated how much of the original fluid was in there still, I found that .37 liter of the old antifreeze remained along with .37 liter of the old water. These figures are based on the system holding 14.5 liters when full.
That was good enough for me, I then added 7.25 liters of Zerox and topped it up with distilled water.
See the old post here.
