Old Mar 9, 2015 | 07:46 PM
oledoc2u
Default Re: Throttle is messed up **Video **
Are you just revving the car setting still. If so, that is normal. It has a limiter so you won't over rev the engine. Going down the road in normal operation, it should be fine. If that isn't the case, sometimes the throttle pedal will come loose from the mount and slide down a bit, not giving you a full throttle. Good luck.
