Mrmiata
I hope your not using the one that came with the larger housing.. those are basically throw away. Did you do a throttle reset with the gas pedal?
I'm not, I have followed the Pdf that's given here to the last detail and used the old oem maf sensor meter. I have tried several times to do a TB reset. You know, Turn the key to on, press on gas pedal for 5seconds, turn off key, release gas pedal but leave key on, wait for 5 minutes. I Checked every line and it's plugged in. The code that is throwing out is a bad maf. The weird part is that I had a v8 maf meter on my old tb and that worked great. The sensors look alike and I have also tried that one with the same result. I just don't know what else to try. I have read many people who struggled and got it to work. I don't know what I'm doing wrong.
