Old Mar 12, 2015 | 10:14 AM
onehundred80
Default Re: 74mm throttle body problems
Originally Posted by Jlgo2011
I'm not, I have followed the Pdf that's given here to the last detail and used the old oem maf sensor meter. I have tried several times to do a TB reset. You know, Turn the key to on, press on gas pedal for 5seconds, turn off key, release gas pedal but leave key on, wait for 5 minutes. I Checked every line and it's plugged in. The code that is throwing out is a bad maf. The weird part is that I had a v8 maf meter on my old tb and that worked great. The sensors look alike and I have also tried that one with the same result. I just don't know what else to try. I have read many people who struggled and got it to work. I don't know what I'm doing wrong.
BoilerUpFire had problems like this and a nice drive to the Dragon cured it for good. So just drive and see what happens.
I did the same mod on my old NA and I had no problems from the start at all. So who's to say why it happens.
