Re: Skreem module
If you can lock the doors remotely then the fuse that controls the alarm system hasnt been removed. This tends to be the case when the module is malfunctioning. If you had a new or slightly used key you would see instructions on how to turn the beep on and off. Hope this helps! Enjoy your trip!
