Re: Motor Mounts
Sent a PM to you with the specifics but the place you buy the coated cable will have the clamps to hold them tight .....basically a ushapped bolt with a bottom flat piece to run the ubolt through and put a bolt on each end and tighten them up. I used 3 to be sure of no movement of the cable and in 4 years have never broken another motor mount.
