Old Mar 14, 2015 | 09:10 PM
thesurge237's Avatar
thesurge237
Default 2004 crossfire key stuck in ignition
Hey guys,
I have a 2004 crossfire coupe with about 134,000 miles on it. up until a couple months ago the car had been a dream with no issues whatsoever. Then it hit the fan. First the fuel control module started going out which led me to replace the crank position sensor and later the relay itself when I identified that was the issue. Then not 15 minutes after i installed the new relay and was basking in the victory of driving my car again. The shifter stuck in park. Then after finally noticing the small trap door below the "D" which covers the shifter release i was able to shift out of park.
Now i can shift in and out of park as much as i like but i cannot remove my key from the ignition. The steering wheel lock also no longer engages which i feel must be related. Even with the motor off i can rotate the tires however i please. Has anyone else ever encountered this issue? My key still turns and starts the car just fine but i cannot remove it from the ignition. Car runs and drives like a dream.
On another note when the fuel pump control module went out the car sat for a month or two with the rear spoiler extended and now the interior switch wont work. Where should i start troubleshooting this issue?
Thank you.
