GraphiteGhost
In picture two, is that a crack running past (down) the right side of that channel where the rear window starts? To the far right of the channel looks like a crack all along the right side of that channel. Right below that wet dirt.
That Crack is the factory seam between the two panels and it is still sealed up good as I could see.
That channel where the dirt is, is from the trim piece I poped off (which came off alot easier than I thought) was trying to be as careful as I could when I took that seal off, do not know where to find a new one.
As I said when the headliner got wet the car was not moving, just sitting in my driveway. At times rain did come down pretty strong.
Has anyone had problems with the grommet that runs the wires from the hatch back to the car?
Door window seal looks good, but window seal is to low for the water to run in that direction.
Might pull the grommet and all seals and silicone them and put them back on.
