Re: Srt Turns over but does not run
[QUOTE=ala_xfire;830841]Does mean :
1. the engine turns over but does not start
2. nothing happens when I turn the key
Sorry #1. Starter turns engine over like normal but does not start.
Also, lots of rain and water. Pulled foam out and pulled plug to drain at least a gallon. Working on drying up inside of pump. Lower inch was in water. Three pins on on the lower connector are gone. I will try and resolder new pins and other corroded components. Prices to replace are 250-600. Now to try and find the leak. Could this be causing the starting issue?
