Old Mar 24, 2015 | 04:07 PM
tighed1's Avatar
tighed1
Default Re: Srt Turns over but does not run
Have seen more and more fuel pump relay coils going bad.
Can you hear the fuel pump energize for a couple of seconds when you turn the key to the on position?
If not could be the fuel relay.
To test if the fuel relay is bad, Open the RCM and close the contact on the fuel relay (#4, see picture). If car starts and runs, Ta-da! You found the problem.
I can fix that for ya. :-)
Another way to check w/o opening the RCM------
Shoot Carb cleaner (something flammable) into throttle body and see if car runs as long as you are spraying. If it stops when you stop spraying. Good chance it's the fuel relay.
