onehundred80
Or the unit was placed in a sturdy plastic bag, with no holes in it and not sealed up.
hhmmm...I don't recall the sealed bag was the
end solution....'cause the pump's gotta pump air to (and from) the latches...the pump needs to suck/push....hence I think the bag idea led to condensation/sweating...which was one water source..
..the other was water used to run down the filler cap yellow pneumatic hose onto/into the unit and..
.. if you didn't/don't keep your rear gutter drains clear (SLKxxx), water may enter the trunk/boot...run down to the trunk floor and then sit and sweat+cause more condensation around the foam box hosing the PSE (
the pump unit we are talking about)....etc...etc...
after thought....I just re-read your "
not sealed up comment" I get you...
