Old Mar 27, 2015 | 12:44 AM
amx1397
Default Re: Any red flags or advice on purchasing this SRT6?
the car looks good in the pictures ,,,look under the doors, the only place you may find rust. make them a offer of 11500. also take the car out for at least 20 min ride ,,,get on it ,try to heat it up The supercharger I mean,,as the car will not heat up after you go wot 5 to 6 times if bad the supercharger pump will stop working ,,but only for a few min. when the SC pump does not work , you give it gas and it feels like what the hell i am not moving. have them take money off if that happened u can fix that for around 100. also look up the sticky key print a good page and tell them this is a problem that will happen take money off again. now you should be around 10,000.00 good luck jim
