Thread: New Member
Old Mar 27, 2015 | 09:23 PM
  #39 (permalink)
csteve0355's Avatar
csteve0355
Default Re: New Member
Originally Posted by Bill T.
Good Evening,
I am going to CT tomorrow to check out this Crossfire. If it is OK I think I will make a deal. I will get back to you. THANKS for all your help.
I know I said I was going to stay away from 04's but this one does look PRETTY good. Tomorrow will tell. CarFax came back with NO PROBLEMS.
Bill T.
For me its the best color. From the pictures I can see it still has its original Varta battery - which you should change out as these cars are temper mental when the voltage gets low. Do a good walk around, check the bottom of the door plate with them open as they can rust if not maintained, and that all things work - then take it for a drive............Good luck
