Old Apr 2, 2015 | 06:57 AM
  #255 (permalink)
stevo1384's Avatar
stevo1384
Default Re: Crankshaft Position Sensor
Originally Posted by xfire2005
This should do it for you.
Service and Repair
REMOVAL
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner housing.
  3. Disconnect the crankshaft position sensor harness connector.
  4. Remove the retaining bolt and the crankshaft position sensor (1).
INSTALLATION
  1. Install the crankshaft position sensor (1) to the engine. Tighten to 8 N.m (71 in. lbs.)
  2. Connect the crankshaft position sensor harness connector.
  3. Install the air cleaner housing.
  4. Connect the negative battery cable.
IM about to set this car on fire Hahaa. No codes!!!! Cranks but no fire, it used to fire up then die after one second. If I hit the gas before it died it would stay running changed all the spark plugs now it won't start at all it will crank two sometimes three times then nothing I triple checked the plug wires there on good. Still no codes unhooked the battery same scenario. Re sodered the joints on the RCM before changing the plugs it still ran after that IM thinking ignition switch maybe cause sometimes it won't crank. What should I do please help guys I really like my 06 roadster
