Old Apr 4, 2015 | 08:19 AM
ala_xfire
Default Re: Automatic DRL Daytime Running Light switch?
As GG said above, you remove the TOP cap that has all the labels, then you can remove the cover under that to see the 2 metal terminal strips at the rear of the box.
One of those is "always hot", and the other is "ignition switched".
You will see a nut on each holding wiring connections, tap into the desired one with a wire and a ring terminal of the appropriate size.
