Re: Need step by step procedure to test for leaks
Water in the trunk related to headlamps? I don't follow that but if you suspect the trunk leaking I wouldn't test for leaks but inspect under the foam inserts in the trunk where the locking module is. If there is evidence of water in there you know it leaks. My bad memory seems to recall something about the fuel filler drain as a possible source and the SRT6 wing mounting screws as a source but don't recall it on the NA spoiler.
