Old Apr 8, 2015 | 09:35 AM
KDW4Him's Avatar
KDW4Him
Default Re: Need step by step procedure to test for leaks
Originally Posted by barngal
They are replacing the sticky ignition at no cost to me. I was planning to do the fix myself, but it is so convenient to have it done, now, and I can fix it when the problem surfaces again. They are also replacing the back tire, which was very worn and wearing unevenly, so now we have 4 new tires.
Too bad you couldn't get your hands on the new ignition switch and remove the pin so there will not be a "next time".
These cars don't have adjustable camber arms, if you did investigate doing an alignment read over the threads that talk about the aftermarket parts. It might save you a second trip back to the dealer.
