Old Apr 9, 2015 | 08:21 PM
RED DOG's Avatar
RED DOG
Default Re: Electromagnetic clutch out on SC
Originally Posted by Shelbygto2
So this is out and needs to be replaced. I took it to dodge and they diagnosed it. If i dont get it repaired can it cause other damage?
Its around $1700 there to do it. I assume with the motor at a lower compression running without the supercharger could be dangerous.
Thankfully I have an extended warrenty and they are covering all charges minus $100. So they are replacing that and the harmonic balancer. I am going to make sure they know that when they fix this and the problem is still there I am not paying another $100 deduct. Lol.
Sorry but I'm confused here . . . You "took it to DODGE and they diagnosed it". There isn't a Dodge dealer anywhere in the country who could diagnose anything on a Crossfire SRT6. Then you say it will cost $1700.00 to fix it but later tell us you have an extended warranty (sp) and they are covering all charges minus $100.00.
AND now they are replacing the "harmonic balancer" (the crank pulley) too. What exactly are you here asking for advice about? If you're comfortable taking your car to a Dodge dealer and you have an extended warranty, I guess you should just let them start throwing expensive parts at the problems until they happen to fix the problems (or not as the case may be).
Good luck and let us know how everything turns out . . .
