Old Apr 11, 2015 | 10:00 AM
onehundred80
Default re: Difference between Base vs. Limited models Coupe and Roadster 2005 - 2008
Quite possible you could have. As I understand it, the 04's had different rear axles than the subsequent models. Haven't personally verified that though.
If you look at the parts lists you can see that the '04s are held in with 4 screws and 4 retainers on each side of the diff. Later years are different.
'04s have the same shaft both sides and later years have a left and right hand shaft.
