Old Apr 11, 2015 | 07:11 PM
onehundred80
Default Re: Installed the Brabus Monoblock V wheels but...Need TPMS
Originally Posted by MAYAman
I don't have TPMS that fit these wheels, the opening is a little smaller. What can I do? I have been searching online and all I see are the stock sensors.
Also, a weird problem. After I took the car away after the alignment, the cruise control will get to 70mph and then shut off, no cruise control. What the hell?
Surely these wheels have the same size holes that fit the standard stem, if the standard stem fits the TPMS will fit as they are the same size, the metal stem cover goes on when the stem is installed. Some TPMS do not have the metal cover.
If the tire is larger in circumference by a certain amount the cruise will disengage when the wheel speed differs from the speedo by a certain percentage. I think that is the reason. That may not be your condition though.
