Old Apr 12, 2015 | 12:09 PM
oledoc2u
Default Re: Which module is it, help
I will assume you have done the obvious and went thru the fuse box to make sure nothing blown or corroded enough not to be making contact as well as making sure all connections are good and clean as well to each of the modules and sensors mentioned. Chasing electrical is a nightmare and hard to answer on here. We have to assume so much, it's hard to give you the right info the first time. But, what I mentioned gives you that code. Good luck, I am out of it now that you have help.
