Old Apr 12, 2015 | 12:15 PM
oledoc2u
Default Re: Waterpump shop labor
ZeroxG05 is for aluminum engines. Just make sure the coolant is specified for this. I am with 180 on this, as rarely the water pump fails. Other pulleys and sometimes even the alternator make noises. If the pump were failing I would suspect you would have coolant seeping around the shaft of the pump. Good luck... That is all I have to add, you have help now...out of here.
