Old Apr 12, 2015 | 12:33 PM
oledoc2u
Default Re: Which module is it, help
Originally Posted by skarlet
Thanks, I ordered an ABS pump off of Ebay, i will try it, and yes i have checked the fuses, connections and what i think of as the easy fixes, if anyone has other suggestions, please let me know, and i will try them, i have not been able to disconnect the connector to the abs/cab as yet i do not want to break it. There was another thread from last year, so i figured i would see if anyone else had run into this unique set of symptons as they had the same things show up but appear to have sold it without fixing it, i was unable to find a used part on ebay and did not want to throw $1000 at it and find out it was not the solution, i will try this $142 part. $142 is not so bad as $1000.
Good luck. It's a ***** to trace down all the possibilities for sure. Given the code and the lights, that's my best guest. Hope it works.
