Old Apr 13, 2015 | 12:24 AM
  #57 (permalink)
amx1397
Default Re: Performance Differential Gearing
Hay Squirrel Crusher, & Doc. I had to weld the gears , without a posi (wave-trac) I would have spun the pass tire off. LOL to do a proper test i has to weld the spider gears. as some of you know I had a 178 lower crank pulley I broke it,,(cracked at the keyway) as of this day and testing I will try my best to stay with this timeline.
----------------------------all test done with my V8 Crossfire-------------------------------
test one,,, stock pulleys upper and lower with 327 gears, I ran in a row 11.27, 11.26, 11.27 DONE
test two,,, will be stock pulleys and the 346 gears----------- Maybe next week
test three,,, will be stock lower pulley V8 smaller SC pulley 346 gears ------by end of April
test four,,,will be 185 crank pulley with 346 gears---- by the middle of May
test five,,, will be both(stacked pulleys & 346 gears---by the end of May
test six,, back with the 327 wave-trac and both pulleys. by the end of June.
if this works out , Rudy and I are looking at a 373 or 391 ..
Mike I;ll trade you a rear and tcu of your choice for your hood,,,,LOL
