Old Apr 14, 2015 | 01:38 PM
onehundred80
Default Re: Installed the Brabus Monoblock V wheels but...
Originally Posted by MAYAman
OK update.
The fronts actually fit perfect no spacers. The rears also fit but are too far in, I need spacers to bring them out. Doesn't look awful, just not as good as the fronts. What size spacers should I use?
Also, I contacted Brabus and they said I need to use Mercedes pressure sensors as the wheel is built for those. They didn't designate a model number. How would I get that to work with the Xfire?
The current sensors thread is too large to fit in the Brabus hole by a small amount. I'm not even including the metal collar.
thanks
edit:The cruise control issue happened twice and then never came back. Weird.
What size hole is it?
The hole has to be large enough to take the rubber seal location diameter which is about 7/16 diameter on the standard Schrader sensors. Maybe what you have has to be opened up to size.
