There is no grinding down part of the assembly . . . Look here . . .
Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Read everything / Look at all the pictures / Print it out and then go fix your problem. ALL Crossfires will eventually have this sticky ignition key issue. Fix it now before it gets worse and becomes more complicated to fix the problem.
