Old Apr 17, 2015 | 06:56 PM
hustler316's Avatar
hustler316
Default Re: H&R Front Swaybar Improves Autocross
Originally Posted by MJPowers
Wes
The front bar keeps the front outside tire from dipping and the rear inside tire from lifting. See if you have an issue with that. For me, I liked the way the car handled in all other aspects of transition, but I finally had enough evidence to fix that performance gap.
Hope your R7s are working well. My A7s really warmed up fast, and the mega-sweepers that were set up almost overheated them in 5 runs (few cars, lots of runs). TireRack says they will last longer than R6/A6, but taking care of them (psi, temp, alignment) is a must.
Mike
Just a heads up, the A7 and R7 require alot more pressure in them, like 44 to 46 hot. Hoosier changed the side wall construction from the 6's.
