Old Apr 19, 2015 | 01:38 AM
tighed1's Avatar
tighed1
Default Re: Srt6 suddenly lost all power and stalled
The only relay contact I have seen go bad is the Air Pump relay (Fault Code - PO410).
As I have mentioned in other posts I have been seeing more of the coils in the Fuel Pump relays going bad. Apparently the coils are opening causing the relay to not operate. AND it appears the problem can be intermittent. The windings in the coil will make/break connection so the car will/will not run or run very crappy.
