ala_xfire
Start with the 3 BIG fuses in the box in front of the battery.
Remove the negative battery cable before touching any of them though.
Remove one fuse at a time and at least nail the drain into
1. ABS
2. RADIATOR FAN / control Module
3. everything else.
If it's "everything else, remove ALL the fuses from the under hood fuse box and put them back one at a time watching the ammeter.
That's about all I could suggest.
Thanx, I did try the 3 big fuses, and only the 200 amp stopped the drain. I already removed all the fuses one at a time, with no help. Would removing all the fuses, and replacing them one at a time be any different? IDK.
