Old Apr 20, 2015 | 01:01 PM
ala_xfire
Default Re: Big time battery drain.
Originally Posted by Abaton6
Thanx, I did try the 3 big fuses, and only the 200 amp stopped the drain. I already removed all the fuses one at a time, with no help. Would removing all the fuses, and replacing them one at a time be any different? IDK.
All it would prove is that the drain is not caused by anything fed by the fuse block if you remove all the fuses and the drain continues. could be some sort of feedback ?
