Old Apr 20, 2015 | 03:05 PM
KDW4Him's Avatar
KDW4Him
Default Re: Big time battery drain.
Originally Posted by Abaton6
Thanx, I did try the 3 big fuses, and only the 200 amp stopped the drain. I already removed all the fuses one at a time, with no help. Would removing all the fuses, and replacing them one at a time be any different? IDK.
If the 200 amp stopped the drain, put it back in and work downstream from there. Use the service manual schematics to know everything that feeds from that fuse. Pull one fuse at a time while watching the meter, you will find it. Just takes time.
