performanceisland
I have a similar issue, my 2003 slk32 amg with 45k miles on it has a supercharger clutch that appears worn just like the op shows but no wear on the shaft, just on the surface area, i noticed this while removing it to upgrade to the eurocharged smaller pulley, should i be concerned about this? replace the clutch? or smooth out the surface of the clutch somehow? or don't touch it at all, thanks.
I'm not sure I understand .... The OPs pulley is broken, NOT worn. If your pulley is broken similarly, your choices are replace pulley or replace supercharger. Based on your description, the supercharger shaft (and presumably clutch surface on supercharger side) are still OK ... so replacing the pulley should take care of it.
perhaps some pictures would help If it seems to you that we are not on the same wavelength here.
Cheers,
Chris
