List of resettable Crossfire features
PDF.
Keep a copy in the glove box.
The throttle body reset
1. Get in your car
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 minutes for a full alignment.
6. Drive the car as you always do.
Disabling the seat belt warning chime
1. Turn the key to ON/START - within 60 seconds, turn ignition OFF and fasten the driver seat belt.
2. Start engine and wait for the seat belt light to turn off.
3. Within 60 seconds unbuckle and rebuckle the seat belt 3 times - ending with it buckled, you will hear a single chime (sometimes this verification chime is slightly different just the same it works to disable the chime).
The chime confirms you have turned the repeater chimes off. Repeat the sequence or disconnect the battery to restore the reminder function.
Disconnecting the battery will reset the chime and you'll have to do it again!
Resetting the FSS setting after changing the oil
1. Move the ignition switch to the “RUN” position.
2. Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second. The display for the FSS service
request is activated for 10 seconds
3. During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position.
The FSS service request will continue to be displayed.
4. Press the reset button for the trip odometer and
hold.
5. Move the ignition switch to the “RUN” position
6. Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display.
The tool symbol should disappear at this time.
Programming the fob for one or two doors to open with one press
The fob can be programmed to open the drivers door only with one press and the passenger door and trunk with two presses. Or, open both doors and the trunk with one press.
Instructions to change the programming you have now.
Press both lock and unlock buttons at the same time and hold them down until the red light at the top of the key fob blinks twice. Repeat this operation and the change to the programming is undone.
Disconnecting the battery will reset the chime to the default setting which is opening the drivers door only with one press.
Fob programming with a new fob or after battery changes
1. Press either the lock or unlock button momentarily twice.
2. Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Setting the clock on the dash
To adjust the time display, turn the key in the ignition switch to the ON/RUN position.
The ****/button to the left of the clock is used to change the time.
Pull out the **** and turn to the left for hour adjustment and turn it to the right for minute adjustment.
Resetting the BAS/ESP light
1, With the engine running turn the steering wheel all the way to the left..
2, Turn the steering wheel all the way to the right..
Automatically lock the car at 9mph (15kph).
1, With the key in the ON position, press the interior lock button upper portion for 5 seconds.
Or
2, To deactivate this feature press the lower portion of the switch for 5 seconds with the key in the 'ON' position.
