Old Apr 27, 2015 | 03:09 PM
Cubanfisher's Avatar
Cubanfisher
Default Re: Mechanical/Transmission Poss Issues/NIGHTMARE time trying to find issue! HELP!
Originally Posted by jtaylortech3
MAJOR UPDATE!!
I have FINALLY found what is wrong with my car and even better after months and months of a nightmare situation it is finally fixed! It turned out to be the ABS module/pump, relay for spoiler, wheel sensors and some switch/cable that was under the transmission stick!
After having it as Chrysler as I mentioned before, they had suggested that they thought it was the "abs module" but because of the fact they wouldn't guarantee that and wanted stupid money just for the part! I then ended up sending it to this place in Lancashire after doing a lot of research (long way as I live in Wales) but as I have free recovery it wasn't difficult to get it up there. Within 2 days they had it all sorted and fixed so FINALLY its now back on the road and is like new again! No more warning light and more importantly NO more Limp mode!!
So yeah its been a long road but am very happy and pleased! Thanks to anyone that gave me there input and tried to help.
Btw Jesticle - I will put any money on it being the Abs module, it seems to cause all hell to break loose! That was my car's main issue (obviously were combination of things in my case) but it seems that its very likely its that, especially if you are having the same symptoms! Best of luck with getting it sorted, feel for you as I obviously know how distressing it can be. If you need to ask me anything, feel free too
Thanks,
Justin
hello just wanted to thank you for posting the final update on your problem. ive done a lot of research. ive got the same situation as you, almost identical! and just received a new/used abs module in the mail today and going to put it in this week. thanks again ill post my results
