Anyone have this problem with their top or know whats wrong or how to fix it? I was trying to glue the back window on because it fell out. I figured lifting up the back would be way easier then getting inside the car to glue in such a tight area. When I let it back down, the top would no longer go back up by the hydraulic motors. I can manually put the top down and up again and there is some resistance. (making sure the pressure is released of course). I checked the fluid and its good, everything works as it should. Windows go down automatically when I pop the top open, the compartment in the trunk is hooked up correctly.
