Re: need help with A/C problem.. compressor not engaging
When the car runs out of Freon the low pressure kicks the entire system off to protect components. You can cross the wires on the low pressure switch and the system will come back on. If that works replace the low pressure switch. Just guessing as I can't see the car. When you cross the wires on the low pressure switch you can put more Freon in as the compressor should come on.
Ken
