Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
xxx_fire
I went to autozone and picked up a soldering iron for $8 and thought I could do this myself since it looked easy enough. I have never soldered anything before.. This is the outcome...
..... My car is still dead... HELP !!!
I suspect the $8 soldering iron does not have enough wattage to heat those big pins. Here is a video showing how solder flows with the correct temperature (wattage) iron. In our case we need way more heat than the samples in this video.
https://www.youtube.com/watch?featur...JxytERvg#t=146
This video should start at the 2:25 mark.
Simular workflow except in our case the pins are bigger and there is already solder there, we just need to heat it till it flows back around the pin while adding a little more solder.
