Old Jun 16, 2006 | 10:49 PM
HDDP's Avatar
HDDP
Default Re: Dyno Finally (depressing)
Originally Posted by +fireamx
Derek, I'm going to go way out on a limb here, and take a very un-educated guess (since I'm no mechanic). But could it be running lean because of the Saskins intake is actually "too" efficient? Also, aren't you running headers too? Wouldn't these two mods alone help create a lean mixture if the cars computer couldn't compensate for the increase air flow?
I'm not defending Powerchip, but I would think it was probably programmed for an otherwise "stock" engine.
Good points... I'm thinking it may be running lean because the CATS are gutted, yet the 02 sensors are still in place causing the ECU to trim back fuel... Any thoughts on this ?
