Re: Possible SKREEM module.. cont. from another thread
Aloha all,
My 05 Roadster did the 'won't start but everything works' today.
The key fob would not unlock the doors, thought the fob batteries died.
When I got in and tried starting the car it did not turn over but all dash lights lit up fine.
Then the alarm went off and I could not stop it. The fob did nothing. Inserting the key did not shut off the alarm. Locking the door with the key did not stop the alarm.
Alarm would stop on its own after a minute. Then the side marker lights would blink for several minutes. (seemed this was a way of saying the car was immobilized) I could hear a clicking or sound like a blinker behind the dash/vents. Sorta like the wipers on intermittent mode...
I tried rolling the car back a little, swapping the fob batteries, and nothing worked and the alarm would go off again.
Open the hood and the alarm would go off. What an embarrassing situation. Everyone in the parking lot was eyeballing this.
Not much I could do as the few tools I had were stuck in the locked trunk.
So a call to roadside assistance and a tow to the shop was needed. A quick check of the car battery and it was fine.
After a while the guys at the shop figured out if you pull fuse # 9, a red 10 amp fuse, that isolates the door locks SKREEM etc.
I could then start the car. No interior lights, door, console, or trunk locks though. Oh and Sprint Booster was disabled too.
But while the car is running I had them put the fuse back in, of course the SKREEM sets off the alarm but I could unlock the trunk and center console and car stayed running. Whew.
So in an hour they figured out that fuse 9 was a bypass to that SKREEM module.
So I am driving it with no worries. I will order a used Ebay SKREEM module (door lock control) and see if it works. If not able to program key or something I will send one to SOS for repair/programming.
Hope someone else with a SKREEM no start problem tries pulling fuse 9 and can post their outcome.
Cheers!!
