Re: Advice sought.
if the same diff wasn't reinstalled and a different diff was then you have to shim the bearing to get the correct backlash . this accounts for the diff whine and the reason the seal is still leaking. since you don't have to change any of the alignment adjustments to remove the diff theres no need to realign if its right the first time
