Old May 14, 2015 | 07:23 AM
ala_xfire
Default Re: How do I remove the entire Headlight Assembly/Headlamp(s)?
George, the 'trick' is to remove the 2 big hollow lower mounting adjusters after the bolts have been removed.
You then remove the 2 upper fascia screws and you should then be able to remove the light assemblies.
When you put them back in, just get the hollow adjusters started ( after the assembly is back in ), insert the upper mounting bolts and tighten, then run the adjusters up until they just contact the mounting tabs. Insert and tighten the lower bolts.
( You DID already insert the eyebrow lights and connect the headlight harness, right ? )
