Old May 16, 2015 | 04:36 PM
minimayhem's Avatar
minimayhem
Default Double wrench service confusion...
Today I changed the oil on my Xfire. Its on 64K and is an 06 model. I have no service history, but the FSS was indicating it was oil chance time.
So for good measure, I replaced the oil, oil filter, air filters and auxillary belt and coolant. Im going to do the fuel filter in two weeks. I greased everything hinge wise and am going to go through all visible bolts, remove, clean with a wire brush and refit with grease. I've already done most under-car bolts. I'm also going to get the car on a lift and put anti-rust coating on the underside.
I reset the FSS today and it now says 10,000 miles a double wrench is due. But I thought double wrench was due at 60,000?
Although I have no service history I know the front discs and pads are new, the rears are looking very good (disc and pads) and all four tyres are brand new.
I read the double wrench service post and also had a look at the service schedule, but I'm hell confused - should I just ignore the double wrench and do standard?
