Thread: Forum Etiquette
Old May 17, 2015 | 08:00 PM
dedwards0323
Default Re: Forum Etiquette
Originally Posted by RED DOG
Oh . . . and by the way . . . you posted your concern in the wrong category!
GregWork - This fact alone makes searching a tedious task at times. Many of the threads get "off stream" when a fellow Forum Member digresses from the original inquiry. So one has to learn to use the Advanced Search and look for references to a particular issue you're having. You'll be surprised sometimes where the answer you're looking for is found.
The TSB's & How-To Section under Technical is an excellent area to find the solution to many of the Crossfire's quirky traits. Many of the Forum Members have spent considerable time putting together threads that really drive home Corrective Repairs & Improvements to the Crossfire.
And if you're still not able to locate what you're looking for, start a new thread in the appropriate category and someone will eventually steer you in the right direction. And yes, you'll probably get some feedback occasionally that rubs you the wrong way. Learn to recognize the individuals that respond that way and ignor their responses if at all possible. (Not that easy for some of us!) But it makes for an interesting forum!
Later,
