Caliper brake clips
maxcichon, thanks for your reply, even though it wasn't what I wanted to hear.
Is there some trick to getting the end in the remaining hole? Sure not helped by it being bent downward. The closest I came to installing it (the unfortunately) correct way was with using needle nose vise-grip pliers.
How is the enclosed moly brake lube to be used?
Is brake bleeding on a car with ABS any different than with pre-ABS brake systems?
