Old May 19, 2015 | 07:29 AM
maxcichon's Avatar
maxcichon
Default Re: Caliper brake clips
Yep. Just what the old Canuck said...
I bought one of these:
Amazon.com: Mityvac MV6835 Vacuum Brake Bleeding Kit: Automotive Amazon.com: Mityvac MV6835 Vacuum Brake Bleeding Kit: Automotive
...and it's turned out to be the coolest/handiest tool I own. Using compressed air and a little venturi vacuum generator, it, as stated, creates a vacuum one uses to suck liquids from...anywhere. If you can't drain a reservoir, you can use this to empty it.
You may be able to borrow a similar unit from a local autoparts store?
Or do it the old, uncool way!
There are also replacement bleeder screws with built-in check valves. For doing it yourself, with no air sucked back up the lines!
Google "Speed Bleeder". Amazon carries them.
