Old May 21, 2015 | 01:44 PM
James1549
Default Re: Front Marker Light as Turn Signal
Originally Posted by SuperD500
Thank you Jeff!
I already thought I would have to do some splicing, but that's okay.
This sounds very interesting and relatively easy to do.
But ..., I am not too familiar with the terms you're using. What I do know is that each bulb has a positive and a ground (negative), a '+'and a '-'.
Do you mean that the side marker ground should be disconnected and be connected to the front turn signal positive?
Jim.
Check any older GM car, they used this method for years.
This method is sure to mess with the 'light out' bulb on the dash.
