Caliper brake clips
maxcichon, no, yes you're incorrect that you are incorrect. Got that?
Along with being a lower viscosity it does have a higher boiling point - 509 degrees F, which is getting up there. Not sure what this means, but the Wet boiling point is merely 338 degrees F.
Many years ago I boiled the brake fluid on my '85 Alfa GTV6 at the Streets of Willow (should you know where that is).
