Old May 22, 2015 | 11:10 AM
amx1397
Default Re: Squeal noise from engine
Originally Posted by West Peterson
If it were the throwout bearing, would it continue to squeal after the clutch was disengaged?
it could be the brakes, the worn out marker may be touching when you take off.
it is is a errk--errk errk type squeal it coukd be the u joint on the drive shaft.,,,, seen that
it could be a pulley bearing squealing only under load.,,,, seen that too
you may have a loose belt,, in fact that is what i think it is. put some belt lube on your belts and c if it still does it. jim
