Thread: Limp Mode!!
Old May 25, 2015 | 04:23 PM
Binky's Avatar
Binky
Default Re: Limp Mode!!
Originally Posted by waldig
Just do this for me, check the coolant level and tell me that the color is clear, no milky contents. I have had something odd happen to me and with and without my pully the car would lose power. It still ran and if I let off of it it would come back in the next gear.
1st wide open about 5500, droop in power, second gear 5000- 5500 droop, third power up to 4000-5500 droop. Does this sound familiar??
PM me if you wanna. If the above looks like yours you can contact me to understand this. I see that you tried to pass and lost power, but I would like to get more of your details. There is a lot of haten going on with the I/C pumps and Iam trying to get more data to track this and related power losses.''
Woody, Enjoy
The dude is right , get that code before doing all the work, as I believe that your car runs normally without WOT operation?
My SRT6 did the same thing, it starts chugging, I took a video and you can see the engine shaking, and the exhaust sounds wrong. I also took a shot of the rpm, slowly bring it to 3k, then when I slowly let off, it hits 1500rpm or so and boom, back into chug mode. I leave the car sit for 30 minutes, start it, drive home. I'm totally at a loss. I have changed the crank sensor, next is my IC pump, because the SC clutch sounds like its trying to click into position, and then the stuttering starts again. please someone help. I do not get any codes, no check engine light. although in my video, the ESP/BAS light came on but went away as soon as u turn the engine off HHEELLPPPPPP. id love to show everyone this video so they can relate. how do I do that?
