Old May 25, 2015 | 06:02 PM
amx1397
Default Re: Did I read where a member had pulley machined?
[QUOTE=latemodel21;837076] If you are thinking something in the 65 range, better to find a steel code3 rather than mess with machining.
]If you are thinking something in the 65 range, better to find a steel code3 rather than mess with machining.
Chris I am so glad you said steel pulley,, as we know the aluminum ones aren't that good,,. the rivets when riveting steel to aluminum will not last jim
